Vss
Old Nov 28, 2004 | 12:07 PM
hookedon3gen's Avatar
Car: 88 camaro
Engine: 383 carbed
Vss
I have installed a painless harness in my 88 camaro, I am running a tbi fuel system, of course I have a ecm. My question is my 700r4 does not have a plug for vss, I do have part that I can install and hook my vss to it and still use the cable. My speedo is cable driven and I guess it has the vss that goes to the tach. I do have to replace the tach since it came out of a v6. So I am keeping cable speedo and changing tach. Do I have install vss that goes to ecm or ?
Old Nov 29, 2004 | 11:25 PM
Vader's Avatar
Your '88 Camaro speedo head should have the VSS installed in it. Pontiacs went to the transmission mounted VSS in 1986, and Chevtolet went to them in about 1990, IIRC. If you have a cable to the speedometer, you should have the VSS on the back of the speedo head.
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
