Fuse Amperages?
Old Nov 28, 2004 | 04:01 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Fuse Amperages?
Howdy!
I'm just doing the finishing touches on my TPI swap into my 80 GMC pickup, the last component is my new fuse box, but I need to know what some of the amperages are. All these are coming off the underdash connector (I added a few wires for my convenience):
D Fuel Pump Power Feed
F ECM Power Feed
G EGR Power Feed
N Injector bank 1 Power Feed
P Injector bank 2 Power Feed
R Cold Start Injector Power Feed
Also, there is a heavy gauge orange wire that runs to the fuel pump relay, MAF power relay, and MAF burnoff relay, as well as to the ECM in two places. Does this wire need a fuse, or does this wire need to have a fusible link? Either way, what amperage fuse / fusible link does it need?
Thanks for any help you guys can help me with
Old Nov 29, 2004 | 11:13 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Anyone willing to take 5 minutes to look under their dash and write them down? :lala:
Old Nov 29, 2004 | 11:32 PM
Vader's Avatar
The ECM/Fuel pump power supply should be protected with a 20A, standard time delay fuse.
The INJ1 and INJ2 fuses should each be 10A.
The EGR should be powered through the 10A GAGE fuse.
The Cold Start Injector and Control should be powered through a 3A fuse, identified as the CRANK fuse in many stock panels.
Old Nov 29, 2004 | 11:34 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Thank you very much Vader!
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
raymondandretti
Sep 27, 2015 06:43 PM
lanceflame44
Sep 25, 2015 12:28 PM
