Wiring up my MSD 6AL box, and have a question.
Old Nov 30, 2004 | 02:49 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I have all of the wires ran except for the red ignition(12V switched) wire. I just want to know where is the absolute BEST place to hook it up to. Thanks a bunch, Paul Moore
Old Nov 30, 2004 | 03:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
find the main ignition on power wire that feeds the fuse box, and tap into that.
Old Nov 30, 2004 | 03:57 PM
paulmoore's Avatar
That's just the thing, I don't know which one is the right wire. I have two heavy red wires that go to a box type thing on the top side of the steering column. Also, coming out of the main part of the column are some wires that go to a gray connector. Is that wire part of that connector?
Old Nov 30, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Paul, the red wire that comes into the car at pin "A4" of connector C100 on the driver side firewall is the ignition wire. It splits inside the car and branches off into four directions. Two of the wires go to the ignition switch located on top of the steering column. The other two go to the fuse panel. One is for the "LID" fuse and the other one is for the "PWR ACC" circuit breaker.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Bryan F
Aug 18, 2015 02:28 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
