Delay Wipers
Old Nov 30, 2004 | 06:24 PM
stenseltizm's Avatar
Car: 89 RS
Engine: 400 sb
Delay Wipers
how does the wiper switch vary the delay between pulses? Is it a variable resistor? I found some of Trickster's diagrams through the search, and that's what it looks like to me, but I don't understand every symbol in a schematic.
Old Nov 30, 2004 | 09:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Go check your e-mail.
Old Nov 30, 2004 | 10:17 PM
Car: 89 RS
Engine: 400 sb
nothin new so far. was it too big?
Old Nov 30, 2004 | 10:30 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
less than 2 mb sent about an hour ago to your yahoo mail address.
Old Nov 30, 2004 | 10:35 PM
Car: 89 RS
Engine: 400 sb
hmm musta been lost, thanks anyway
do you know what the resistance is for the different settings on the delay switch? I'm trying to create something, i'll post results if my idea works.
Old Nov 30, 2004 | 10:45 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I have just re-sent the schematic symbols to you. There is not a resistance value to it, it operates off a logic circuit board in the wiper motor case. If you need it I can send you the chapter on the wipers.
Old Nov 30, 2004 | 11:00 PM
Car: 89 RS
Engine: 400 sb
Wow it's like a whole crash course in automotive wiring.. thanks. I may have some toubles with what i'm trying to do then. How does the switch signal different delay times to the motor? I have a bad switch, and every switch in similar car's i've had are similar poor switches. I was trying to modify a switch I have from a newer car, but i would loose my variable delay.
Edit: of couse the original one shows up AFTER the second. ha
Old Nov 30, 2004 | 11:10 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It has to do with the wiring from the harness on the steering column to the wiper motor.
Old Dec 1, 2004 | 05:36 PM
Car: 89 RS
Engine: 400 sb
What does the wiper switch vary to signal a different delay? As I stated earlier, I assumed resistance, but I am told I am wrong. So what is changed?
antman89iroc
36
Jan 31, 2016 08:42 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
