What exactly does the comp have control of?
Old Dec 1, 2004 | 09:00 PM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
Im swapping my motor out in winter and i was wondering what will work and what wont if i just rip the whole computer system, cause its going to be a carb motor, or what can i plug back in to make it still work right? Thanks alot, much appreciated.
Old Dec 2, 2004 | 04:41 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
if your going carbed- you dont need any of it, strip it all out get an HEI system from the junkyard, im using a mechanical fuel pump- if your not worried about emissions ditch it all from the ECM to the O2 sensor. you will need to take out the VATS system too i beleive- i just ripped all the wireing out and made my own harness for only the stuff i need. if its an everyday driver i wouldnt do a carb though- its do the LT1 swap. Non computerized cars tend to be a lil touchy and ****. youll also need to work on the guages and what not- make a custom autometer pod like im doing it makes it all easy. if you have any questions just PM me ill be happy to help ya
Old Dec 3, 2004 | 01:40 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The computer controls the ignition and transmission lock-up.
Without a working throttle position sensor (TPS), nothing will work. The ECM would be stuck in Limp Mode.
Old Dec 3, 2004 | 10:56 AM
Axle/Gears: peg leg
ok, but if im switching to a carb'd motor im going to replace the whole ignition system, so do i need still have cause im also getting a different torque converter and transmission.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
sandman92084
Sep 12, 2015 10:27 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
