Underdash fuse and wire pic. needed
Old Dec 11, 2004 | 11:08 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
I need an actual picture from under someones dash on the drivers side so i can see where everything hooks up. I see this as the only thing holding my car back from being done. There is only a handful of things left to be done. I still can't get the headlights to work!
Here is what I came up with
-Tail Light extension (it meets by the back seat)
-Ground for fuel pump. Super easy
- Hook exhaust up and weld
-Tie rod
-Convert to a newer windshield washer and heater unit.
p.s. the wires are already in the fuse block (we did a whole dash swap) I just need to see where the wires hook onto the car and on the fender wall ect. ect. the car is an 83 the dash is from an 89 I do have dash lights, RPM's and Im sure MPH. I get all the readings I can.
Thanks!
Old Dec 13, 2004 | 04:27 AM
Car: 83 Trans Am
Trickster? Anyone?
I need to see what a normal car's underdash wiring on the drivers side looks like. Someone has to have a pic or can easily get one
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
