lights dimming!!
Old Dec 12, 2004 | 07:52 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
lights dimming!!
Ok this is really pissing me off. i have an 140 amp alt in my camaro and i just put in a 600 watt amp in my car. when my bass hits my light dim only when my subs are hitting hard. i just put in a new alt. do you think my battery could be the cause.!! ( i dont think i need a cap)
Old Dec 19, 2004 | 05:38 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
this si a good thread to be in car audio but how is you batt??
Old Dec 19, 2004 | 05:41 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
lol yeah you do need a cap obviously... possibly a new battery also.. walmart has cheap batteries.. id get the battery then see how u are..was everything fine without the system hooked up? like ur voltage? so u kno that ur not losing power somewhere else... see my car was fine untill i hooked the Rf1001 bd up to it.. so i blew the subs later on.. now i killed my alt and now the car struggles to stay at 11v...u should be fine tho must be the battery i think that alt u got would solve ur problem but if the battery isnt holding the charge .. ur sol
Old Dec 19, 2004 | 05:44 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
id step to an alltima battery if you got the cash.. the should be better for your buck
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
