Coil Pigtails and No Start
Old Dec 13, 2004 | 05:00 PM
jasonrmorrow's Avatar
I had no spark after my TPI swap from carb, i thought somehwere i only needed the coil to dist wiring with the pink and white wire. I'm using the Painless harness, do i run switched and run 12v directly to the pink wire or does the ECM send that voltage ? I have fuel.
I only have one of the connectors from the coil to the dist, what is the black connector for ( i don't have that one).
I ran 12v to the pink wire cranked three times and it went dead and now i have voltage at the battery and horn relay but no lights horn anything, so.... fuseable links at the starter ?
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
L98GTA87
Aug 5, 2015 11:02 PM
