Car wont start need help!!
Old Dec 15, 2004 | 09:22 PM
Drewace's Avatar
Car: 1985 Pontiac Friebird Trans Am 305 TPI Recaro
my '85 305 T/A wont start anymore. it started fine i drove home then went back out to start my car and nothing happened. first i thought my battery was dead but it was fine so i figured it was the starter or solinoid so i got a new starter and installed it but it still wont start. i then thought it might be the neutral safety swith but i tried giggling the shifter and turning the key and it started then i drove it and when i went 2 start it again it did nothing i had to take apart the consle and i jumpered the purple and yellow wire in the neutral module and nothing happened and i tried moving the module and taking it apart and still nothing so could it be the ignition key switch or am i missing something. the battery is charged but nothing will turn on ecept when i open the door with the key out the interior lights come on but when i turn the key nothing works and i dont have vats so i guessing the ignition switch but how do i test it in the steering column?
Old Dec 16, 2004 | 01:11 AM
Morley's Avatar
One other HIGH failure item to check...fuseable links, in the harness down at the starter.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
