Need help on distributors
Old Dec 22, 2004 | 10:56 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Hey guys; I need some help trying to decide which distributor is best for my car. I decided to remove my TPI intake this winter to get at a bad lifter, and I started thinking about replacing the distributor with a high performance one, such as Accel, MSD, or Mallory. I can't seem to find one that will work with my car; all the ones I've seen have vaccum canisters on the side and mine doesn't. I have a 1985 IROC-Z 305 TPI engine in my 1988 Camaro SC. Anyone out there have any advice as to which distributor would drop right in and hook right up?
Also, how hard is it to install one of those MSD boxes; I think it's the 6AL or something like that. I figured I'd put one of those in too while I'm back there. Maybe pick up a little more power and whatnot.
By the way, the motor is stock, but the only thing I think that would affect the ignition is a Hypertech Thermomaster chip, if that helps out any. Thanks!
Kevin
Old Dec 23, 2004 | 12:14 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
If your factory ignition is in good shape, chances are you won't see any performace improvement form a high dollar ignition system on a standard non-modified engine.
The distributor you want is call a "small cap HEI" computer controlled distributor. I know MSD makes them, the others probably do as well.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
