No instrument lights 1988 transam
Old Dec 21, 2004 | 03:54 PM
blackroc68's Avatar
My instrumment lights stopped working. I have no power at the fuse.The green wire with the white stripe dims and brightens with the turn of the thumbwheel. at the gm dealer the parts man said there is a seperate switch. anyone have more detailed wireing then my haynes manual,after this switch th wire switches from green with white stripe to solid green.anyone?? trickster?
Old Dec 22, 2004 | 02:36 AM
Morley's Avatar
He meant that the lights are turned on and off with the headlight switch. Pull it out and clean the contacts on it and on the harness and try that. If that doesn't do it, find the wire on going to the inst lamps from the headlight switch and verify it has continuity and verify it has power when the headlight switch is on.
Also check your under dash grounds.
Old Dec 22, 2004 | 06:37 AM
blackroc68's Avatar
there is a remote dimmer switch somewhere.anybody know where its located?
Old Dec 22, 2004 | 11:14 AM
Morley's Avatar
Never heard of any "remote dimmer" in any 3rd gen unless you are reffering to the firebirds which have a seperate thumb wheel for dimming lights, but it just sits beside the headlight switch.
Old Dec 22, 2004 | 12:29 PM
blackroc68's Avatar
there is a remote dimmer.it has a heat sink to cool it.
Old Dec 22, 2004 | 01:18 PM
Morley's Avatar
That would be the normal light dimmer then, has a large metal heatsink on it.
Old Dec 22, 2004 | 08:28 PM
blackroc68's Avatar
That is called the remote dimmer. the regular dimmer is the thumb wheel.
Old Dec 23, 2004 | 05:34 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I once had the same problem on an s10. I know that the s10 did not have a remote dimmer, but what the problem was, one of the liscence plate lites had shorted out. It happens that the liscence plate lites and the dash lights were on the same fuse.....
Old Dec 23, 2004 | 09:53 AM
Morley's Avatar
No "remote" dimmer in bodies.
Old Dec 23, 2004 | 11:11 AM
blackroc68's Avatar
Just to let you no there is a remote dimmer its located on the right of the steering column it is a transistor with a heat sink. My car is a 88 transam it is a f body. you learn something new. i Found this remote dimmer replaced the transister.lights work
Old Dec 23, 2004 | 12:27 PM
Morley's Avatar
Hmm, none in my 91 formula, or 85 IROC, possibly a T/A only option.
Old Dec 23, 2004 | 12:48 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
the remote dimer is built into the swich on camaro but yes the 88 trans am/GTA do have a dimer in it is loacated on the right side of the callum neer the flasher's there is 3 wires going into it and if you replace the dimmer and it still douse not work you can jump two of the wires together with a fuse if you decide to keep this way for good i would run the wires into the fuse box and put a fuse there. The downfall of this is that the lights dimer will not work.
Ghettobird52
Jul 5, 2024 11:18 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
