headlight and dimmer switch ?
Transmission: TH200C....700R4
Does this headlight switch I got off a newer third gen bird fit my 82.Its just that the set up the 82s had was hheadlight and diimer switch are horizontal and the switch/dimmer are vertical in newer third gens so I dont know if the newer third gen headlight and dimmer switch will fit my 82 s/e?
heres a pic of the headlight and dimmer switch I want to install but not sure if they will line up?
dont worry about the power mirror switch,I posted a another thread for that.Heres the headlight and dimmer switch the car came with.........
ok ,I guess I have to go to the yard and test out my gray dimmer and headlight switch for myself in this 84 bird tomorrow .......
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
They should work...but why not get the correct 82-84 black switchs from the dealer? They are all still available and not too expensive. I replaced the power window and door lock switchs on my '84 and the window switchs were about $8 each and door lock switches about $4 each. This is probably the first time my power window switches have said UP and DN since 1984!
I can get you the part numbers if you need them. I have a 82-92 parts microfiche that my dealer gave me.
Well,my swithces are fine but I was just curious ,besides ,I kinda like the gray ones and if the ones I have now break at least I know the gray ones will fit.thanks dens71TA.
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
