Do sensors work off voltage or ohms?
Old Dec 29, 2004 | 10:15 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
Before I put the 383 in, Im puttin in all the supportin mods. Main thing Im concentrating on now is the gauges. I want to run full electronic gauges, only mechanical I wont mind wud be FP, but thats gonna be under the hood anyways. But, since Im runnin carb, computer's out. So, I was wonderin if anyone knew if the major sensors (oil press and temp mainly) worked off of resistence, or if they have a 5v reference. If they work off resistence, in theory I could have all electrical gauges right?
Old Dec 30, 2004 | 10:50 AM
goofnrox's Avatar
Factory gauges do not use the computer, just wire them up and you're done.
Most aftermarket gauges come with their own sensors, and just need a 12 volt supply.
The sensors work by varying the resistance in the sensor.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
