View Poll Results: Silverstars or ebay hid conversion
Silverstars
65.00%
Ebay HID conversion
15.00%
Neither, factory all the way
20.00%
Voters: 20. You may not vote on this poll
Silverstars or wanna-be hid conversion
Old Jan 14, 2005 | 04:43 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Alright should I go with a set of silverstars or with these from ebay? http://cgi.ebay.com/ebaymotors/ws/eB...tem=7946854397
The ones on ebay would only be $10 or so more.
My friend has silverstars and I'm pretty pleased with them however the ebay ones sound alright too.
Old Jan 17, 2005 | 10:54 PM
Car: 91 Camaro RS
Wow, aligning the headlights and cleaning the connections up sure does make a difference too.
Old Jan 22, 2005 | 03:28 AM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Wanna-be HID
Be careful of some of those conversions that advertise 100/80 W that will work in an OEM 55/60W system - They will not. All of a sudden when the higher wattage overheats the system the lights go out, most likely on a dark and narrow road. Or they start to flash on and off because of overheating the system. Stick with 55/60W H4's and they will work, plug and play. Cocacolakidd
Old Jan 22, 2005 | 03:58 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Those eBay ones aren't HIDs. Just blue painted regular bulbs. Get the silverstars. I haven't had experience but all I hear is good stuff. Those painted blue bulbs prevent some light from coming out. Sure it looks white/blue, but it is actually dimmer than a comparitive bulb.
Old Feb 3, 2005 | 05:33 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
looking at what this guy says I wouldn't trust him or his product
to many things that dont fit well
"100/80w High Wattage light output with only a standard Watt current draw."
wattage = volts x amps
so since a car batt with the alt going lets say puts out 14v
so a 55watt bulb is goin to draw 3.92 amps of current
so a 80watt bulb as he says would draw the same amount of current?
lets see at 14volts I get 5.71amps of current flowing
difference of 1.8 amps
doesn't quite sound the same to me
Old Feb 5, 2005 | 12:26 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I've got silverstars in my TA and they are great. I just went for the plain silverstars, not their blue light or XD ones or whatever they call them.
Linson
Oct 24, 2025 02:00 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
