Keyless Entry Woes
Old Jan 17, 2005 | 05:51 PM
Slow2.8's Avatar
Keyless Entry Woes
Trying to hook up the keyless entry with a Rattler alarmsystem. It has a negative door trigger and a positive door trigger. What wires do i connect these to? Color wise, i know where to look for them.
Old Jan 18, 2005 | 09:02 AM
nogoshowboat's Avatar
Car: 1991 RS
Engine: 3.1 L
Transmission: th700r4
Keyless Entry Woes
the door locks on my 91 rs are a negative trigger with my clifford alarm. i had to use a 30 amp relay to get them to work hope that helps if not contact me and ill give you a diagram on how to wire a 30 amp realy to work good luck
Old Jan 18, 2005 | 10:17 AM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
http://www.bulldogsecurity.com/
Old Jan 18, 2005 | 03:21 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
http://www.the12volt.com/doorlocks/page3.asp#5w
There web addy or look for info on 5-wire door locking. You'll need two relays (or a door lock mod, just two relays in one box) and trigger that from the (-) trigger for lock and one for unlock out of the brain.
Old Jan 18, 2005 | 04:28 PM
Slow2.8's Avatar
Alright so i gotta buy a relays, or even make them, whats the diagram? If it's easy to make it myself i will if not i'll just buy it.
Old Jan 19, 2005 | 06:30 AM
Car: 1991 RS
Engine: 3.1 L
diagram
okay you will need to get
- 2, "30 amp relays' (available at most part stores i got mine at radioshack)
- a spool of wire
- some female spade connectors
- some patience
you can try to make relays but its cheaper to buy them they are only like $7 - $10 in canada so US expect lower. and wire them like this
Old Jan 19, 2005 | 09:25 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I’m wrong. You don’t need relays (or 5-wire) because our cars have them. Know though that using the relays to isolate things never herts, and if you don’t use them and some how you hit the in car buttons and the remote buttons at the same time bad things could happen. Most GM do need to be 5-wire because the switch terminals rests at ground and are wired right to the lock solenoids, but not our cars (at lest not in 86, all should be the same). Look here. And note that it is a (+) trigger not a (-) trigger.
http://92b4crs.tripod.com/86wiring/dia-pics/130-0.jpg
Your brain should have door lock outputs something like this (+) unlock/ (-) lock and (-) unlock/ and (+) lock. If you look at the wire diagram you’ll see in the car the unlock wire is black and lock is light blue. So take the (+) unlock from the brain to the black wire and the (+) lock from the brain to the lt. blue wire. Of course confirm all wires with a VOM first. And like I said before, it is best to use relays even though you need to, I would use them.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
