installing new fuel gauge
Old Jan 18, 2005 | 01:36 PM
har0xz's Avatar
Car: 1986 Pontiac Trans Am
Transmission: TH-700R4
1986 trans am
my car was originally equipped with the digital dash cluster. the wires are all still there, and i was wondering which wire can i use to install a aftermarket fuel gauge. im looking for the wire that goes to the sender. also is it possible to use the old sender or will i have to replace it. thanks
Old Jan 18, 2005 | 10:26 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is the pink wire going to pin "5" of connector C2 (34 pin connector). If you need a pin-out of the digital cluster connectors let me know and I will post it later. BTW, you can use the same sending unit.
Old Jan 18, 2005 | 10:43 PM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
there are three wires neer the hump in the backseat that will give you the idea of what the wires look like
Old Jan 19, 2005 | 03:16 PM
har0xz's Avatar
the connector was cut, i think i found the pink wire tho. do you have a diagram of the wire colors and what each of them does?
Old Jan 19, 2005 | 03:43 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
Try this, it might help http://www.hioutput.com/tech/speedo.html go to the wireing printout link and it will list all the dash connecters and the color wires
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
justin57
Aug 20, 2015 07:05 PM
fonzie85
Aug 13, 2015 11:50 AM
