'85 Power hatch fit on '87?
Old Feb 13, 2005 | 11:50 AM
Demon355's Avatar
Would the '85 power hatch motor fit and work with an '87 GTA power hatch? Mine's toast and I can get this one for cheap. Thanks
Old Feb 14, 2005 | 12:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If it is a motorized hatch pull-down unit it should work. I see pull-down units on eBay often that are incorrect for the years listed. I also see solenoid hatch releases misrepresented as either a motorized hatch pull-down unit or that it will fit years that it won't. Post a picture of the unit here or e-mail it to me and I'll know for sure.
Also while I'm at it, I sell all the parts to rebuild your hatch pull-down unit (in case the one you get from eBay turns out to be a DOA). Just click on my link above.
Lon Salgren
Top-Down Solutions
Old Feb 14, 2005 | 01:23 AM
Demon355's Avatar
I see....now that you mention the solenoid unit, I'm pretty sure thats what it is. The motor itself doesn't seem that big and the mechanism is way smaller than the one I have. Would it still bolt up right? Would I be able to use the push button opener?
Old Feb 14, 2005 | 09:35 AM
lonsal's Avatar
Does it look like this?
If so, then yes you can install it on your hatch pull-down unit.
Lon
Old Feb 14, 2005 | 11:43 AM
Demon355's Avatar
Yes!
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
