Gauge Cluster Electrical Problem
Old Feb 14, 2005 | 05:38 PM
Boomhower25b's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: ZZ3 350
I have an 85 Camaro. When I turn the head lights on the voltage gauge drops to nothing, sometimes the right directional indicator lamp will come on and glow solid without turning my actual directional, and at least one of the backlights for the tach doesn't work.
Does anyone have any idea on what’s going on here?
Old Feb 15, 2005 | 06:15 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Without a schematic of year model, venture to guess loss of ground (Bat Neg) for the headlight circuit. Think circuit trying to P/U grd thru signal light that glows.
Old Feb 15, 2005 | 10:39 PM
17wth85z28's Avatar
Car: hmmm, camaro site.....
Engine: 305.... TEAR
Transmission: t-5 soon
MY 83 z28 did the same thing. New headlight switch did not fix it. My instrument cluster was not pressed into the connectors fully. Our gauge clusters are press-fit plugs. I loosed mine, pressed it tight, and then bolted it back up. worked perfect ever since.
Old Feb 15, 2005 | 11:57 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Gently take out the gau. cluster. Check for signs of corrosion on all contacks. Male and female. Clean with rubbing alchol a q-tip and a reassemble.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
