12v ignition source in engine bay
Old Feb 19, 2005 | 01:41 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Are the smog pump electrical connections 12v or 5v? I am hooking up my electric fan switch and was looking for an easy to use ignition wire to connect that was under the hood. Any recommendations? The search keeps coming up funny for me.
Old Feb 20, 2005 | 05:20 PM
Car: 91 Camaro RS
TTT, I don't have access to a voltmeter right now and I don't feel like toasting this relay.
Old Feb 22, 2005 | 10:16 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i would tap into a pink wire with a black stripe leaving your fuse box. all pink wires with black stripes are 12v switched on the inside. just run the wire threw the firewall threw an existing hole. (speedo cable, a/c grommet, etc)
dont burn anything up.
Old Feb 27, 2005 | 09:12 PM
Car: 91 Camaro RS
If I were to use the Smog pumps ign wire, I would need to ground the other wiring coming from it correct?
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
Jae992
Aug 27, 2015 09:07 AM
jahblah
Aug 12, 2015 05:54 PM
