Positive battery cable question
Old Feb 20, 2005 | 07:37 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Where does the pos battery cable bolt to. It runs from the battery down below the cooling fans, up onto the right side rail and it is just hanging there. Does it bolt directly to the starter or somewhere else I can't see. Thanks.
Old Feb 22, 2005 | 01:24 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
It should go to the starter solenoid. On most gm moldels the solenoid is on the starter. Other makes may be on the starter or on the firewall or inner fender(like fords). Hope this helps.
Laters,
Conrad
Old Feb 23, 2005 | 02:40 PM
Notplayn's Avatar
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Accerrito22
Aug 23, 2015 07:22 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
