Gauge Cluster Swap 86 Into 82
Old Feb 22, 2005 | 10:41 AM
Jeff Morgan's Avatar
All,
Just completed the gauge cluster swap (86 into an 82) and everything works perfect except the speedo. Not sure why, because I followed the instructions to the letter. Guess I need to check output readings from both the buffer and transmission in order to see if I'm getting voltage from either. Any ideas from you guys will be most helpful.
Jeff Morgan
82 S/E
Old Feb 22, 2005 | 04:10 PM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
This is how I did mine in my 84
http://la.rsson.com/speedo/speedo.html
Old Feb 23, 2005 | 12:25 PM
J.
Thanks a lot. I now see what my problem is. I using the incorrect connector into the VSS. I'll let you know how it comes out in a coule of weeks.
You've been a great help.
Jeff
Old Feb 23, 2005 | 01:01 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Glad to be of help, if yoy're missing any of the parts I have a couple of spares I can part with cheap :-)
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
