Wiring 4th Gen Seats
Old Feb 23, 2005 | 08:10 AM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I got a set of '00 Formula Leather Seats. They should be easy to wire up as the only power they have is power drivers' tracks. (no lumbar on either, and pass. seat is manual.)
The driver's seat has a clip coming out of it connected to an orange, and a black wire. I figure black is ground, and I will connect that to one of the bolts that holds the seat down.
My question concerns the orange wire. I know this has to be connected to a 12V power source (probably the fuse box), but what is the best method for doing this? Should I just jam it into the utilities space? Or what?
I would like to do this the right way, so that it doesnt fail on me in the future.
Any input appreciated.
KZad
Old Feb 25, 2005 | 11:06 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
if you have your seats out, pull up your carpet and look under it. there might be a connector there. GM uses the same harness on a variety of cars. chances are its there. if not you can hook it to any orange wire comming off the fuse box for constant power, or any pink(black stripe) wire if you only want power to the seat when the ignition is on.
good luck.
Old Feb 28, 2005 | 07:47 AM
KZad's Avatar
Thanks Stage, however, I got your post a little late (this morning). I put the seats in Saturday. Probably while you were making your post.
I felt around the carpet while the seats were out, and didnt feel any harness. What I did was simply splice a wire in behind the connector coming from the seat and run it to the fuse box. I tapped into a "battery" open spot, and therefore the seats have constant power.
Everything works properly, and the seats look awesome.
Old Feb 28, 2005 | 06:25 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
i love my TA leather, i wouldnt trade it for anything. well, maybe.
Old Feb 28, 2005 | 10:54 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
what i did was just hook it up to the power window switch in my camaro. works fine. just cant roll my windows down while i move my seat. works really good and also cant move it when the car is off. havent had any problem yet. lol
Old Mar 4, 2005 | 10:58 AM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
i have some seat's from a 94 trans am.driver's does have the lumbar support.can i do the same
Old Mar 4, 2005 | 05:04 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
pretty sure you can. lumbar might pull more juice and blow a low amp fuse, but i doubt it.
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
