switching to carbed 350 need help
Old Mar 8, 2005 | 04:51 AM
gearhead351w's Avatar
Car: 87 GTA
I have a 87 gta rolling body I have a 350 and a 700r4 trans the question that i have is with the trans I know that it has the lock up converter but what will i need to do to make it work I have no idea what year the trans is it came out of a 85 t/a with a cable drive speedo will I need to do anything with the tv cable need help! I know that I need a return style regulator the car was fuel injected. also where can i get a better tork arm mount somthing better than stock any help would be great
Old Mar 8, 2005 | 09:48 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Alot of questions can be answered by reading the ENGINE SWAP section. They have a sticky for FAQ that will help you out. For the tranny lock up check out the Tech section at the hompage, its got a right up for it. For a torque arm mount check out Spaun, or read over and search the suspention boards. Im guessing the combo is not running yet? or is it? If not, find out what carb your using, then search for pictures or hook up diagrams, must make sure your finding the correct linkage for a 700R4, more specific information spread out over the forum will get you better results with the answers.
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
