prom problem (one for the books)
Old Mar 8, 2005 | 10:25 AM
richard5167's Avatar
92 rs car will not start or run with prom installed will run without prom however not correctly. gm says prom is bad however i have two ecms and proms and they both work in another car. any ideas can you help?
Old Mar 8, 2005 | 09:04 PM
Vader's Avatar
That just about takes it right down to the ECM connector wiring and beyond. If a replacement ECM and PROM thjat works in a different vehicle doesn't work in your's you need to look outside the ECM - possibly right outside.
On the other hand, if the "test car" is a different model/year, there may be some differences.
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
GTAman
Sep 21, 2015 09:57 AM
greenyone
Sep 2, 2015 03:39 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
