stalling problem
Old Mar 17, 2005 | 12:38 PM
dollarbill425's Avatar
Car: 89 Camaro RS
stalling problem
ok i put a new race distributor in my 89 tbi it starts fine but the idle is a little low at first, but the computer compensates for it, for about 10-15 seconds in which it runs good then it starts to idle down stumble then die...i set base timing at 0 degrees, computer doesn't give me any codes... could this be a vacuum leak???
Old Mar 17, 2005 | 08:48 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try setting your base timing a little higher, say between 6 & 10 degrees.
Old Mar 18, 2005 | 06:37 PM
Car: 89 Camaro RS
ok thanks i'll try it
Old Mar 19, 2005 | 02:02 PM
Car: 89 Camaro RS
ok i set it a few degrees higher then a few degrees higher than that, upon start up its fine but when it starts to idle down, the comoputer starts to move the timing closer to tdc and when it gets close it dies, i tried holding a timing light on it then when the computer started adjusting the timing i would turn the distributor a little, it would idle back up a little but still die after a couple of seconds...could i be a tooth off?
Old Mar 19, 2005 | 05:26 PM
Car: 89 Camaro RS
ok i put a screw tightener ring on one of the vaccum hoses coming off the intake and the car stays running now at idle, i can give it a little gas and its fine but when i rev the motor a little bit it there is a hestitation but then it rev up but then dies...
Old Mar 22, 2005 | 01:39 AM
Car: 89 Camaro RS
ok i emailed someone who also bought this distributor from an ebay seller and he said the emission system was to blame for the computer to retard the timing, because of the more powerful race distributor
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
