Quick help on a simple question.
Old Mar 17, 2005 | 02:31 PM
Carbonsteel's Avatar
Hey all,
I'm trying to trouble shoot some fuel/electrical issues I'm having with a 92 RS 305 TBI.
On the drivers side firewall you will find two relays right behind the spark control module. Each relay has a four digit number.
One is 1227 and the other is 5311. One is hooked to a grey connector and the other is hooked to a black connector.
I need someone to look on thier car and tell me what number relay is hooked to which connector. I know one relay is for the fuel pump, but I have no clue as the what the other is for and I think mine might be mixed up.
Old Mar 17, 2005 | 08:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If you only have a single fan setup, the two relays are for the fuel pump relay (towards engine) and coolant fan relay (towards fender).
Old Mar 18, 2005 | 08:51 AM
Thanks for the reply, the problem is, that I'm trying to figure out if I got the two relays mixed up. That's why I need to know which color connector goes to which relay.
F-body-fan
Jan 12, 2023 01:49 PM
Pac J
May 17, 2020 10:44 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
