Is wireing like this bad
Old Mar 22, 2005 | 01:32 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
CAn i tap into a power wire and basicly T off of it to a second item that needs power it will be a switched 12 v source. If so can i do this in the middle or is it better to start the wire at the very end of the connection were the wire ends and hooks into the part. I hope you can understand this.
Old Mar 22, 2005 | 04:07 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
What are you going to run? Amp, stereo?
Old Mar 22, 2005 | 04:15 PM
FAST RS's Avatar
A mallory hyfire 6a.
Old Mar 22, 2005 | 04:23 PM
Car: 85 Trans Am
As long as you dont have too much load on the wire (multiple devices) it should be ok to splice into one. Just dont do it half assed with a quick splice
Is this for the V6 or the bird, because i see an MSD on the v6...
Old Mar 22, 2005 | 04:25 PM
FAST RS's Avatar
Its for the bird The only thing on the wire is my fuel pump. Holly Red
Old Mar 22, 2005 | 04:32 PM
Car: 85 Trans Am
As long as its a good gauge wire it should be ok.
Old Mar 22, 2005 | 07:24 PM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
The "right" way to do it (any response that uses the term "right" is going to be opinion ) is to use the accessory terminals on the fuse block.
Running two or more components on the same circuit means that when one fails, they both fail, and troubleshooting is made more difficult.
Not to mention that opening the sheathing on the wiring opens a path for corrosion.
You can get connectors from practically any GM out of the wrecking yard, and just solder/shrink tube the lead to whatever wire you need to power. Inline fuse is also a good idea, but typically GM accessory terminals are all on 30A circuit breakers.
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
