yeah i'm a dumba$$
Old Mar 29, 2005 | 10:15 AM
dollarbill425's Avatar
Car: 89 Camaro RS
yeah i'm a dumba$$
sorry guys don't i feel like dumba$$, thanks for the quick reply though
Old Mar 29, 2005 | 11:28 AM
Car: 89 Camaro RS
sorry i put a reply in the wrong spot, i got the engine running for some reason i forgot to unplug the est after a few timing attempts but it runs good now but there is a hesitation when revving the motor from idle about 1/4 of the pedel down but i think this is normal if i'm wrong someone please tell me i know summit makes a little box for this but i just glad it runs now... CEI-102015 is the part number from summit...
Old Apr 2, 2005 | 03:00 PM
Car: 89 Camaro RS
ok it runs, but after a little test drive i can only give it a very small amount of gas before it starts to bogg down what going on? I was thinking spark maybe but i have an accel super coil, the distributor itself has a high performance ignition module the spark plugs are new taylors, the plugs are just regular ac delco with .35 gap should this be increased or decreased? what else could it be?
Old Apr 4, 2005 | 06:18 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
What motor are we talking about?
Old Apr 5, 2005 | 01:29 AM
Car: 89 Camaro RS
lo3 305 tbi with a 350 block, ihave decreased the gap in the plugs to 30 and it seemed to help a little i have heard that base timing is zero and then from someone else it should be at 6??? anyone know for sure...
Old Apr 5, 2005 | 07:13 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Base timing is 0*.
When you swapped to that 350, did you get 350 injectors, a 350 knock sensor, a 350 ESC module, and a 350 PROM/chip from a 350 TBI Caprice or truck (PROM has to come from a Caprice)? If not, than that's the start of you problem. Your computer still thinks you have a stock 305.
Old Apr 5, 2005 | 02:09 PM
Car: 89 Camaro RS
no i didn't but i've been driving the car for 3 and a half years with no problems, don't get me wrong though i do want to get the 350 stuff but as i'm trying to save like everybody else something comes up and i have to use the money....this wasn't a problem before, this may be the distributor i put in some others have said the hotter spark is playing havoc with my emission system and isn't letting it advance as it should, i'm trying to get an new oem distributor to see if this still happens but that'll take some time, in the mean time i'm trying to figure this one out...
Elephantismo
Feb 13, 2019 12:51 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
89bird2.8
Sep 18, 2015 07:46 PM
CORV3TT3
Aug 23, 2015 11:26 AM
