high mount stop lamps
Old Mar 31, 2005 | 02:27 AM
white80zred89rs's Avatar
Car: 89 camaro rs
Engine: 305 TBI
I have an 89 rs. The high mount stop lamp is on the rear spoiler, and has 5 bulbs in it. All but one of the bulbs is burned out. I've tried and tried to find replacements, but no one has them. I can't even find the bulb number-not even on the old bulbs. Does anyone out there know? Are they expensive?
thanx
Old Mar 31, 2005 | 09:03 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The bulb no. is 891. They're expensive, relatively speaking.
About $8 each, IIRC.
Old Mar 31, 2005 | 10:35 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There have been several posts on here about this topic. If you will do a search you will find them. There is a suitable replacement bulb available through Radio Shack that is much cheaper, I don't have the part number handy at the moment or I would post it.
Old Mar 31, 2005 | 04:29 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I couldn't recall the RS part number either, but I did a search and found where I'd posted the info previously.
The bulb for the HMSL (aka third brake light) is Radio Shack Cat. No. 272-1177. Descr: Halogen Lamps 12-Volt, 20-Watt. G-4 base, rated 350 lumens. Average life: 2000 hours. Excellent for automotive application.
Lon
BRoss99
Aug 10, 2025 05:08 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
