additional cig lighters...?
Car: 91 Camaro RS white w/ T-tops
Engine: original 305TBI 140,000mi
Transmission: automatic (although standard would be preffered)
I was going to put an inverter in my car but it would be used for powering my laptop only and i read a post that said it was a loss to bump up the power just to bump it back down for laptop. I was pondering this while replacing my dash bulbs and realized why should i not just splice new wires into the ones for the cig lighter and buy two new cig lighter holders from a junk yard or something and mount them in a remote and more convenient location? I was thinking of running the wires through the center console and removing the rear ashtray and putting them there. I dont think there should be a power issue with this being that you can buy an adapter to change one cig lighter into two or three and this essentially only a hardwired version of that without a huge thing in an awkward position in the dash. Input is appreciated.
-steve
-steve
Just wanted to bring it up top one last time before i give up.
Car: 91 Camaro
Engine: 191 V6
Transmission: 4L60
It should work, just make sure you get the polarity right when you wire in the new sockets. I am not sure if it matters, but you don't want to find out the hard way it does. Don't plug too much stuff into the circuit, a laptop is fine.
Exactly my thoughts. I'll use the same gauge wire or maybe a tad bigger and if I can get the new ones from a maro the wires will be color coded makingit easier if not i'll trace em into the element itself to match em up. Thanks. Also I was thinking what is the best way to splice the wires in this case?
-steve
-steve
sailtexas186548
Feb 17, 2017 03:07 PM
blackz281le
Jan 11, 2016 07:51 AM
WhteRbt
Sep 21, 2015 09:48 AM
