Do i need this connector?
Old Apr 10, 2005 | 10:27 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
it goes to the transmission but i'm not sure what its for.....i've got a carb'd 355 going in and no computer BS at all, non lockup TCI torque converter, (700R4), i had cut two of the 4 wires when removing all the computer crap, not sure if i can get rid of the other two wires
Old Apr 16, 2005 | 10:50 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I've had some fun with that connector over the past few days.
It's for TCC lockup. Purple wire is for 12v and is switched off when the brake is pressed.
Tan/black is ground from the ECM to tell the TCC to lock up.
The other wire is to tell the PCM when the tranny is in 4th gear.
Should be only 3 wires, not 4 even tho the connector can accomidate a 4th wire.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
