Accel engine management system for tpi
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
i was lookin into burnin my own proms when i can across this product, Accel engine management system directly connects to the ecu of your f body, This power processor is completely reprogramable. Once connected to your Tpi car it can set fuel curves and timing tables. You can adjust your air fuel ratio. It has 2 stage nitrous tables........... does anyone have this, or know more about it, how does it work, does it take place of burning proms? will it work with my 91 tpi 5.7 motor from a z28, its in my 92 chevy truck now. the motor has a bigger cam, roller rockers, flat top pistions, 24lbs, afpr, high-flow tpi setup, and i have a nx nitrous kit i would like to run somday, the truck have a rebuilt 700r4 trans, what do you all think about this itom, will it help me to get the motor runnin the way it should without burining proms also?
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
