rear hatch motor
Old Apr 13, 2005 | 07:53 PM
extreme 1's Avatar
Car: 1989 gta
Engine: 350 tpi
Transmission: 700 r4
rear hatch motor
rear hatch motor will not go up but pulls hatch down fine
Old Apr 13, 2005 | 11:08 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It sounds like a problem with the striker-sensing switch. This small switch is mounted just in front of the latch. Reach down into the hole that the pull-down motor retracts into and fiddle with this switch using a long screwdriver. If this gets it to function, then the contacts in the switch are worn and it needs to be replaced. I have them available on my web site under the Hatch Pull-Down Category. Let me know if yours is a 1986-87 or 1988-91 when you order. I have both in stock new. There was a difference in the connector on the blue wire. 1986-87 have a large white connector. 1988-91 have a small black connector.
Lon Salgren
Top-Down Solutions
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
