TPI to carb swap wiring question
Old Apr 18, 2005 | 05:20 PM
383 rocket bird's Avatar
Sorry this may sound like a simple question but the only wire on the driver side that I have not been able to find the purpose of is a pink wire with black stripe that runs from the ecm to the wire harness on the driver side firewall. I am not sure if I need to take the wire from the driver side and connect it somewhere or if I can just cap it off. Thanks-John
Old Apr 18, 2005 | 07:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Most likly it is a switched 12V + wire. best thing to do would be to disconnect it from the ecm and check for voltage. What pin does it go to on the ecm and I will look it up for you to say for sure.
Old Apr 18, 2005 | 08:00 PM
Thanks for the replies. I actually removed the ecm and am trying to determine where that wire comes from from the column harness. It will be good if it ends up being a switched source as I can then use it as the switched source for the relay. Thanks again -John
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
jharrison5
Aug 19, 2015 05:53 PM
