Electrical short - All rear lights/interior!?
Old Apr 17, 2005 | 02:24 AM
87GTAspeeder's Avatar
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
Hey, I'm trying to find the problem but it's troublesome (as are all electrical!). I'm blowing my rear tail light fuse (usually under a hard bump). Here's all the info...
When the fuse blows I lose my main headlight assembly (to lift or lower the lights, but the lights themselves work), all rear lights (including reverse, stop, and turn), and the interior gauge cluster (I don't lose front lights, dome lights, or any other interior sets).
Also, and I'm almost positive that this is related...When the car is off the stereo unit remains powered! Everything else switches off or on, but the head unit is always powered!? My assumption is that it's a short around the fuse box b/c if I tap the dash, the head unit will power off and the headlight assembly will engage and lower the lights (go figure).
Any thoughts of how to go about finding it or suggestions? I've looked at the electrical manual in the Hayes book, but it seems the systems that are all being affected aren't neccessarily connected... Thanks for the help guys!
Old Apr 17, 2005 | 09:35 AM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
well have you installed anything new, like driving lights, any gauges or anything electrical?
Old Apr 17, 2005 | 09:39 PM
Car: 1987 GTA :)
Transmission: Stock
Nope, haven't installed anything new at all. At first I had thought it was a loose connection in the stereo (b/c it stays on) so I pulled the center dash and checked...There was a bare ground showing on the harness hook-up, wasn't touching but I redid all the wires anyways and that didn't solve the problem so I'm getting ready to just start going through and checking all the grounds...my assumption is that I have a loose ground somewhere
Old Apr 17, 2005 | 09:44 PM
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
well.. are you sure you rewired it correctly? and also. i dont think a ground would cause your cars' lights to act erratic like that. there is a wire touching another wire/body/ground.
Old Apr 18, 2005 | 03:22 AM
Car: 1987 GTA :)
Transmission: Stock
Hmm, you may be right on the ground part, I'll definately be looking for that as I go...and yes I know my rewiring was done correctly, I redid the entire stereo harness and double checked my wires as I went . I don't like to redo things lol. Thanks for the double check though
Old Apr 18, 2005 | 10:28 PM
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
yea.. i sort of have a wring problem of my own.. my temp sensor only works when you turn teh key to start the engine.. , i bet me and you have the same problem
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mizz0313
Aug 12, 2015 06:45 AM
