Power window woes.
Old Apr 29, 2005 | 12:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Power window woes.
So my power windows never really worked right in my car, very intermittently, generally not at all... (This is both power windows..)
Anyway, I had my center console off tonight, and thought i'd check it out. My drivers side worked for about 30 seconds, about long enough for me to get excited and roll down my window... Then it died. It's currently 32 degrees F....
I have a Chilton, and the Helm manual for my car.
I went through the checklist in the Helm:
-Checked for power in pink wire with key in run - ok
-Checked that ground wire (black), was grounded - ok
-Checked switches, for continuity when holding in "up" and down", good for both. (my passenger side is a new looking switch, drivers being old.) both gave continuity (with my digital voltmeter)
- Checked for resistance in the power window motor wire... passenger side got 196ohms, drivers was dead.
*Now remember, both power windows don't work*
What should I be doing now ? Remove drivers door panel (as this is the power window I want to work the most), and check for a loose connection? Can I jump power to the motor to see if it'll move? Pop off a part and check for worn brushes? (anyone have a picture of what i'd be "popping off"?
Thanks very much -J
Old Apr 29, 2005 | 10:30 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Re: Power window woes.
Originally posted by Sonix
...Pop off a part and check for worn brushes? (anyone have a picture of what i'd be "popping off"?
Do a search for Vader's article he wrote on checking/replacing the brushes. I did it recently, and it actually didn't help me at all but it was worth a try. But let me warn you that it wasn't a quick and easy job. There is VERY little room in there to fit your hand (unless you have small hands) let alone a screwdriver or pliers to bend the little tabs to get the plastic cap off with the brushes.
I just had mine replaced by a local body shop. They ripped me on the cost of the motor, but I went down there with the door panel off already and they only charged $20 for labor and a half hour later I was on the road with a working motor again.
Also might try cleaning & lubing the channels. And if you just need to get the window up, with the door panel off try pushing up on the glass while holding the window switch up. It might be enough to get the window to slowly creep back up so you don't freeze to death.
Good luck
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
