Gauge Cluster
Old Apr 30, 2005 | 06:44 PM
87project2.8's Avatar
Car: 87 Camaro
Engine: 2.8L V6
Gauge Cluster
I have an 87 2.8L that I converted from a 700r4 to a T5. I want to put a gauge cluster with a tach in my car. I found one from an 83 2.8 camaro T5. Will it work? Do I need to do anything to make any of the gauges read correctly or is it just "plug and play"?
Old May 1, 2005 | 08:28 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
well right from the get go, no. Since u r converting your basic dash to a dash with multiple gauges you might need new sending units. I can say for a fact you will need an oil pressure sending unit or else your oil pressure gauge will just bury itself, and if you had a temperature light you will need a new temperature sending unit. But the cluster itself should fit where in place of the old one
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
