Using Factory Tach on an MSD Ignition
Old May 1, 2005 | 08:00 PM
Transformula91's Avatar
Car: 1991 Pontiac Firebird
Engine: Chevy 350
Transmission: TH700-R4
I am just completing a v6 to v8 swap in my 1991 firebird and i have encounterd the problem of not having a tach that works. i am using an MSD ignition and i have herd that you can wire the tach into the ignition somehow but im not sure which wire to use. anyone ever done this before??
Old May 1, 2005 | 08:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You've connected the factory tach wire to the tach terminal on the box and it still doesn't work?
Old May 2, 2005 | 09:41 AM
Engine: Chevy 350
weve been trying to locate the factory tach. we first thought it was the white wire that was connected to the coil originally, but when we tried to connect it it didnt work.
Old May 2, 2005 | 12:25 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
That's exactly how I did it on my 91 using an MSD Digital 6 box....
Old May 2, 2005 | 01:25 PM
Engine: Chevy 350
which color cable did you use and where was it located??
Old May 2, 2005 | 02:38 PM
vernw's Avatar
I used the white wire going into the coil, the one that normally has the grey barrel connector on it.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
TrevinE
Sep 14, 2015 03:20 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
