injector pulse
Old May 1, 2005 | 08:18 PM
wildlogger3371's Avatar
Car: 88 rs
Engine: 2.8
injector pulse
how do you check electrical pulse to injectors to make sure they have signal to open?
Old May 1, 2005 | 08:31 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is a device called a "NOID" light that you plug into the injector connector and try starting the car. If the light flashes you are getting a signal to that injector. Disconnect all the connectors from the injectors before starting and then test each one. Reconnect the injector connectors after all the injectors have been tested.
Old May 1, 2005 | 08:34 PM
Car: 88 rs
Engine: 2.8
autozone should have this "noid" light? is it specific to injector wires?
Old May 1, 2005 | 09:14 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes "autozone has them for $6.99 and they are specific to car manufacturer and engine style (TBI, PFI, & Bosch PFI).
Old May 1, 2005 | 09:17 PM
Car: 88 rs
Engine: 2.8
the car was parked for a long time and i was trying to run the old gas out. could i have messed up the injectors in the process?
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
