electric fan
Old May 4, 2005 | 12:18 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
electric fan
my electric fans aren't comming on. i let the temp get up above 220, and nothing happened. also, i tried turning on the a/c and the clutch on the compressor is not turning and the fans aren't turning on. it's connected correctly, but i don't know if it's the motor or wires. anyone know a good way to check?
Old May 5, 2005 | 09:36 AM
eagle_eyes's Avatar
Engine: '93 LT1
anyone???
Old May 5, 2005 | 12:05 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
did u check the fan relay or fuse? def thermistat? loose or brkn connection maybe? check those 1st....
Old May 7, 2005 | 04:53 PM
eagle_eyes's Avatar
Engine: '93 LT1
i think that the fans are working, but the car has to get hot before they turn on...like 230 of so. how can i get them to turn on at a lower temperature?
Old May 7, 2005 | 05:01 PM
WILL85IROC's Avatar
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
TRY A NEW STAT WITH A LOWER TEMP RATING.....
Old May 7, 2005 | 05:22 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Try a in the cooling section, and you will need a new switch, not a thermostat.
Old May 8, 2005 | 01:46 AM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the replies
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
