coolant fan wiring question
Old May 6, 2005 | 03:43 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
This is for a 91 3.1L firebird. Looking the wiring diagram, the fan relay is turned on and off by an ECM output. The ECM gets a temp signal from the coolant temp sensor. The trigger wire for the fan relay also shows that it's connected to a fan switch located in the head. So why does the ECM control the fan and also a switch? Or am I missing something?
Old May 7, 2005 | 06:17 AM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Re: coolant fan wiring question
Originally posted by Ukraine Train
...So why does the ECM control the fan and also a switch? Or am I missing something?
The ECM controls the fan when the AC is on. (The AC pressure switch signals the ECM to start the fan.)
The temp sensor is also to enable the closed loop and for fuel control.
-Ozzy
Old May 7, 2005 | 06:51 AM
Car: '87 Camaro LT
Engine: 355 L98
So during normal operation the fan switch is responsible for kicking the fan on? Not the ECM?
Old May 7, 2005 | 09:12 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Yes but the ECM will also activate the fan based on AC Pressure Switch request.
If you have a diagram you'll see that "ECM pin D12 (Coolant Fan Request) is the signal for the AC, but there is no input from the fan switch. The fan switch activates the fan relay directly.
Note: ECM pin E16 (Coolant Temp Input) is not for fan control.
-Ozzy
Old May 8, 2005 | 04:17 PM
Car: '87 Camaro LT
Engine: 355 L98
Ok, this makes more sense now. Thanks. I'm helping my friend diagnose a problem. His fan won't turn on so I told him the first thing he should try is to turn the AC on and see if the fan comes on. If it does then the fan switch should be the culprit.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
