HI/LOW beam switch
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
HI/LOW beam switch
My hi/low beam switch keeps getting stuck in hi and then instead of going to low, cut completely off and the when I flick it again, they go back to low. Why is this happening and where can I get the switch to fix it? Thanks.
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
the switch is located on the steering column near the floorboard at about the 10:00 position. there is a rod that runs down the length of the column to actuate the switch. see if that rod is loose and/or if the switch is loose. most likely, the switch is loose and a pain in the butt to get to. you'll just have to snug it up...
KAM
KAM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
