no power; head lights,dome,doorlocks,power to stereo
Old May 25, 2005 | 10:41 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
no power to; head lights,dome,doorlocks,power to stereo
my lights dont work there is no power to the red wire at the light switch no power to the constant wire of the stereo or dome lights, or power locks. i think its a fuse but i cant find it! so if some one can help me thanks. (85 firebird se)
Old May 25, 2005 | 11:50 AM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
check your fuse box under neath the dash kick panel on the driver side...
Old May 25, 2005 | 12:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Sounds more like a fusible link off the starter. If you have no brake lights, dash lights, horn, and hazard flashers, it's almost certainly one of the fusible links. One supplies power to the items that work any time - regardless of key position; the other supplies those that require the key to be in either the ACC or ON position, like the turn signals, power windows, starter, ignition, etc.
Old May 25, 2005 | 02:53 PM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
the break lights are fine hazards are fine , its only head lights,parking lights dome lights door locks ,trunk release and hot power wire for the stereo.
Old May 25, 2005 | 03:04 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I would check positive wire to the starter.
Old May 26, 2005 | 06:09 AM
kev2318's Avatar
Car: 85 firebird se
Transmission: auto.
last night i checked the starter wire and it is ok . but then i played with the side post connector on the battary and lossend the bolt and the lights came on for a little bit. now did i reset the breaker by doing that or is there just a bad connection? but when the battary is connected every thing else works.
Old May 26, 2005 | 08:49 AM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
I think it probably has to do with that positive cable, in these cases it almost always does.
BRoss99
Aug 10, 2025 05:08 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
