Is this diagram correct? Custom wiring job...
Old May 27, 2005 | 10:40 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Custom wiring job
Ok, first let me explain. I did a v6-v8 swap, MPFI to Carb. I pulled every last bit of wiring out of the car. Now i'm redoing all of the wiring and I made a diagram to help me. Can you tell me if I have my head in my ****?
R = Relay
S = Switch
I was looking to use 30AMP relays for every relay represented in this diagram. I planned on putting the fuel pump, electric choke and the distributor on the same relay.
I didnt use a relay on the starter, i figured since it will only receive +12v for a short time period, it wouldnt need one.
I have no clue what to do with the alternator wiring. There are 3 wires coming from the pigtail. Where do they go?
Hopefully I have this all correct. If not, yell at me
I did this in Autocad, if you want a copy of the DWG, let me know.
Attached Thumbnails Is this diagram correct? Custom wiring job...-camaro-wiring.jpg
Old May 28, 2005 | 06:28 PM
Car: 88 Camaro
Engine: 310 LG4
anyone?
Jeremys87
Jul 14, 2022 09:08 PM
midge54
Sep 2, 2020 07:13 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
