C240
Old May 28, 2005 | 06:39 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
C240
Hi all,
Could anyone tell me where C240 is on an 89 TPI Camaro? A picture would be the most useful since I don't have such a car to actually look at. Also, if you could say what cavities pass through C240 that would also be much appreciated.
Old May 28, 2005 | 10:55 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Re: C240
Originally posted by blackbeauty
Hi all,
Would you believe that it is located at the base of the steering column under the dash and that it is for the windshield washer and wiper motor? The wires for it are as follows.
Pin "A" = empty
Pin "B" = white to fuse panel.
Pin "C" = gray
Pin "D" = dark green
Pin "E" = purple
Pin "F" = pink
Old May 29, 2005 | 03:53 AM
Car: 1989 Trans Am
Awesome! Thank you once again for your help!
