Anyone tried 4666 headlamps instead of the 4656?
Old May 30, 2005 | 09:30 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
They're the same size, both are a hi/lo beam, but the 4666 is brighter (more Watts). Has anyone installed the 4666 in place of the 4656? Is it necessary to rewire the plug?
Old May 30, 2005 | 11:18 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
If you have the wattage of each bulb (hi and lo) then someone can probably tell you if the wiring can handle it.
F-body-fan
May 4, 2026 09:42 AM
327IROC85
Sep 23, 2015 12:11 AM
CAMAROBEAV
European Region
Sep 12, 2015 10:04 AM
llvll4l2c91350
Feb 5, 2004 08:00 PM
KRUSS
Aftermarket Product Review
Sep 5, 2002 02:21 AM
