any way to make these headlights work?
Old Feb 3, 2004 | 05:38 PM
llvll4l2c91350's Avatar
i bought a pair of silverstars #4656 the other day but didnt realize my car takes 4666 because of the different connection. anyway i can make this work without changing connectors?
the new silverstar is on the left (4656) and one of my old lights is on the right (4666). you can see one pin is set at a different angle.
i already have a set of silverstars installed in the car and i'd like to make these work in case one burns out.
P.S. i know i could return 'em but these were the very last pair in the store (they were tryin to get rid of 'em) and i only paid 2 bucks for 'em.
Attached Thumbnails any way to make these headlights work?-dscn0454-small-.jpg
Old Feb 4, 2004 | 12:28 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
I don't know if I understand your logic....so you want to keep them because one might burn out? Do you plan for that happening soon? If you already have a set I'm sure you'd be fine and I"m sure that they'll get a new shipment in. $2 isn't too much to lose...just buy the one you need when you need it. I wouldn't know if you could still use those.
Old Feb 4, 2004 | 05:13 AM
they're not getting them in again. i asked. i just bought 'em to have an extra pair that way in the future i dont pay full price which is like $25 for each one.
Old Feb 4, 2004 | 06:41 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
As long as they fit in the same bracket, I dont see why they wont work. You will have to go down to the parts store and get connectors that fit. I had a dare i say this, but i had a VW that i changed the headlights out of and put the factorys in when i go to sell it. When you get the connectors, just "parrallel" them with the factory connectors. then later on you can put the factory replacements back in!
Old Feb 5, 2004 | 12:59 AM
Red87SC's Avatar
Car: 87 Trans am
Transmission: built 700R4
Axle/Gears: BW 9 bolt posi w/ disc
you could just send me that set of 4656 lights, im about to go buy some of the coolblue ones for 17$ each
Old Feb 5, 2004 | 01:04 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
or if you have access to a soldering iron you could just solder the wires onto the connectors....dont see why that wouldnt work
Old Feb 5, 2004 | 04:38 PM
yea i think i will keep 'em and make 'em work somehow. it's only one pin that's off. shouldn't be too hard to get it to work.
Old Feb 5, 2004 | 07:51 PM
grngryoutmyway's Avatar
Car: 92 Z28
you could just take apart your connector and then hook each connection to the posts... you'd probably have to put something on there so they stayed connected well, and it would be a pta to get em back off....or you could just buy new connectors
Old Feb 5, 2004 | 08:00 PM
that sounds easy. i'll have to take a look at how the connectors are next time i'm replacing a bulb. i plan to keep using silverstar bulbs and dont wanna pay full price next time i need one (or two).
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
and how would you connect them....with soldering lol like i said above. I work at a place called racetronix and we make fuel harnesses for fuel systems up grades and i spend a good portion of my time there soldering wires to connectors and in some odd cases to uhh its not a relay whats that stupid yellow thing th C5's need lol anyways soldering is so damn easy a 3 y/o could do it, theyre not expensive to buy, you could just take the connector apart and solder the wires on. Would work perfectly if you ask me, id probably cover the connection with some heat shrink though just for good measure
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
tnrednneck
Aug 13, 2015 08:57 AM
