What fuses power these things?
Old Jun 8, 2005 | 10:37 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
Headlight motors (They dont come up or down)
Horn
Cooling fan
Thanks for info,the car is a 91 3.1 firebird A4.I looked at the fusebox but couldent identify a few things.
Old Jun 8, 2005 | 11:15 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Headlight doors= two fuses located in the convenience center.
Horn = ACC fuse and horn relay located in convenience center
Coolant fan = fusible link, FAN fuse, & fan relays.
Old Jun 8, 2005 | 11:20 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Where is the convience center?
Old Jun 8, 2005 | 11:25 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Under the dash by the drivers right knee.
Old Jun 8, 2005 | 11:30 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
sorry but I just ran out and checked...I see the actual fusebox but couldent find anything with fuses under the drivers knee area
Is it possible that my horn,cooling fan and headlights dont work just because of bad fuses?
thanks for all your help man!
Old Jun 8, 2005 | 11:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes it is possible that your problems are with bad fuses. You won't be able to see the fuses in the convenience center unless you drop it down. Look for the ALDL and you will find the convenience center there.
Old Jun 8, 2005 | 11:50 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
How exactly do I drop it down? It there a cover covering it up?
Edit,Whats the ALDL?
Old Jun 8, 2005 | 11:54 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
There is usually a small 7MM bolt holding it up and it should hinge down.
Old Jun 8, 2005 | 11:56 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Thanks alot man!,Im goona go buy a few fuses tomarrow and see how this goes
Old Feb 22, 2012 | 01:26 PM
smokejeremy42's Avatar
Car: 86 trans am
Engine: 355 sbc
Transmission: Th-350
Axle/Gears: 10 bolt w/ 3.73's
Re: What fuses power these things?
WERE ARE THE FUSES IN THAT CONVENIENCE CENTER PLEASE HELP
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Bob88GTA
Aug 18, 2015 03:31 PM
stalkier
Aug 13, 2015 12:59 PM
