altenator voltage reading gauge wrong
Old Jun 13, 2005 | 12:58 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
what could cause this??
its at the first white line when i checked the altenator with a volt meter its showing 14volts
Old Jun 13, 2005 | 05:02 AM
Vader's Avatar
If your handheld meter shows 14V and the dash guage shows something different, either the dash guage is out of calibration or suffers from poor connections. Suspect are the instrument panel connectors, bulkhead connector, and grounds.
Old Jun 16, 2005 | 01:23 AM
Crall13's Avatar
Car: 92 Formula
Engine: 5.7 L
Assuming that your guage is fine, you can adjust it by pulling the needle off the guage and placing it in the correct spot according to the multimeter. The 14V sounds about right, Mine runs at 13.7V
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
355sbcTPI
Aug 19, 2015 04:38 PM
