85mph speedo from 1985 TA to 145 from 1991?
Old Jun 29, 2005 | 08:14 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Right now i have an 85mph speedo from 1985 TA and it is very annoying that it only goes up to 85. I would like to switch it to 140mph, I already have the 140 from 1991 Firebird. They are both 305 V8 one is a TPI one is a TBI. Can I make this work without too much cutting of my dash apart? Is the 85 mechanical or not, I have heard different things. Anyone ever do this swap?
Old Jun 29, 2005 | 08:35 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The 85 is mechanical and the 140 is electirc, what you will need is the buffer box from the 91 and the VSS that goes inside the tranny to send the signal. There is a write up, but don't remember the thread that had the link in it off hand but someone may remember.
Old Jun 29, 2005 | 08:41 AM
Engine: 388 Carb
Axle/Gears: 4.10
you see thats funny, b/c i have read posts that have said 82-84 is mechanical and the 85-92 is electric. I guess i need to find that thread on how to change it over i would really like to have the better speedo, It is so hard to do a sucessful search on here, I get so many threads that have nothing to do with what i want.
Old Jun 29, 2005 | 11:46 AM
Klortho's Avatar
Car: 1987 GTA
Here's the link I was referring to
http://www.hioutput.com/tech/speedo.html
The electric speedo started late 86, my '86 was mechanical, but I bought an 86 cluster from a V8 car for the lens and it was electric, but it was also from a Canadian car.
Old Jun 30, 2005 | 12:00 PM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
My 85 TA has a mechanical speedo. If you want to be sure, look under the car on the drivers side. Near the rear of the transmission, look to see if you have an electrical connector (electronic speedo) or a heavy cable with a screw on connector (mechanical). Seeing is believing.
Old Dec 17, 2014 | 04:19 PM
kuddybing's Avatar
Car: 85 Trans Am
Engine: carbed 350 four bolt
Transmission: 700R4 with shift kit
Axle/Gears: 373's
Re: 85mph speedo from 1985 TA to 145 from 1991?
I have the same problem as u with the 85 in my 85TA.... iv been lookin into swaping to a 140mph speedo out of the 82-84 TA's but cant get a strait answer on if it will work and fit right.... I hear that hawks does a overlay service for the 85mph speedos to go to 140mph but havent found prices are anything on it
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
